[gdal-dev] OGDI 4.1.0 is released
Even Rouault even.rouault at spatialys.com
Sat Apr 20 05:11:35 PDT 2019
I've, un-excitedly, done an emergency OGDI 4.1.0 release triggered by licensing
concerns, so that it can still survive in Debian.
The more I do OGDI releases, the less code there is in it :-)
Download links:
https://freefr.dl.sourceforge.net/project/ogdi/ogdi/4.1.0/ogdi-4.1.0.tar.gz
https://freefr.dl.sourceforge.net/project/ogdi/ogdi/4.1.0/ogdi-4.1.0.zip
The news are
4.1.0
 o  Remove DTED driver that used the ecsrregex.c functionality removed in the
    below bullet.
 o  Remove ogdi/c-api/ecshash.c and ogdi/c-api/ecsregex.c, which were considered
    incompatible of DFSG & OSD (https://github.com/libogdi/ogdi/issues/13)
I've verified it works fine with the OGR OGDI driver and VRF OGDI driver.
Even
http://www.spatialys.com
