[gdal-dev] Confusion between OSM Open options USE_CUSTOM_INDEXING and OSM_USE_CUSTOM_INDEXING
Even Rouault even.rouault at spatialys.com
Mon Aug 5 02:05:51 PDT 2019
On dimanche 4 août 2019 22:42:40 CEST Stephen Knox wrote:
> Hi list,
> There seem to be inconsistencies between the code, the API docs and error
> messages about whether the correct parameter name is  USE_CUSTOM_INDEXING
> or OSM_USE_CUSTOM_INDEXING.
Both are valid:
- USE_CUSTOM_INDEXING as an open option passed to GDALOpenEx()
- OSM_USE_CUSTOM_INDEXING as a configuration option (set with
CPLSetConfigOption()) / environment variable
Even
http://www.spatialys.com
