[gdal-dev] On external PDF libraries
Andreas Neumann a.neumann at carto.net
Wed Aug 21 02:10:40 PDT 2019
I am trying to test GeoPDF support in QGIS and have questions on the
external library dependencies in GDAL. I am trying to interpret the
notes on https://gdal.org/drivers/raster/pdf.html
Which of the three options (Poppler, PoDoFo, PDFium) is recommended? I
work on Ubuntu 18.04 and I can build libraries from source if necessary.
PoDoFo seems limited - so better not use it? PDFium seems to be
complicated to install - so perhaps poppler? Or should I try PDFium?
Thanks for any recommendations,
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190821/c38e9bba/attachment.html>
