[gdal-dev] ogr2ogr: strange results joininig non-spatial CSV to spatial data using SQLite dialect
aborruso aborruso at gmail.com
Sun Dec 1 06:59:27 PST 2019
I have this geosjon (map.geojson)
  "type": "FeatureCollection",
  "features": [
      "type": "Feature",
      "properties": {"id": 1},
      "geometry": {
        "type": "Point",
        "coordinates": [-78.653, 35.7874]
      "type": "Feature",
      "properties": {"id": 2},
      "geometry": {
        "type": "Point",
        "coordinates": [-78.6298, 35.7873]
      "type": "Feature",
      "properties": {"id": 3},
      "geometry": {
        "type": "Point",
        "coordinates": [-78.6408, 35.7795]
and this CSV (tbl.csv)
id,atrr
1,ipsum
2,lorem
3,amet
If I run
ogr2ogr -f csv \
  -dialect sqlite \
  -sql "select map.*,tbl.atrr from map join 'tbl.csv'.tbl AS tbl on
cast(map.id as text) = tbl.id" \
  /vsistdout/ map.geojson
I have
id,atrr
"1",ipsum
If I use left join instead of join I have
id,atrr
"1",ipsum
"2",lorem
"3",amet
Why do I not have three rows of result using simply join?
I'm using GDAL 2.4.2, released 2019/06/28
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
