[gdal-dev] extract wtwdis and unlocd with distance marks from IENC
Lars Schylberg lars.schylberg at blixtmail.se
Thu Dec 12 15:21:08 PST 2019
Hi again,
I had a closer look and it seems like the profiles were skipped when
gdal 2.2 was released.
  All the content from iw and aml profiles was merged in the regular
gdal/data/s57objectclasses.csv  and gdal/data/s57attributes.csv  files.
So this might be a case about what gdal version you are using and using
profile on older versions.
These files can be found under /usr/share/gdal if remember correctly.
There you can look through all possible objects and attributes.
Normally when I analyze a data set, I try and look thru one obejct class
at the time.
First I run a "ogrinfo -summary" to see what classes I have, then
look at each class separately with e.g.  ogrinfo 1W7ML310.000 <one class
at the time from summary>
I was doing some work with aml profile files five years ago, and had to
go thru this examining
of files.   At that time I had to patch some missing attriubutes in the
57attributes.csv for aml.
The procedure is to compare the specification and the content of the csv
file.
But I remember that I played with some IW files from Germany as well and
those displayed just fine.
Good luck /Lars Schylberg
  Den 2019-12-12 kl. 20:25, skrev Wulf:
> Hi Lars,
> thanks for the hint.
>> Have tried the inland water profile?  This is how i did it in the past.
>> This is a config for ogrinfo or ogr2ogr.
>> --config S57_PROFILE iw
> I try to find where the docs describe this, but didn't.
> I'm sure it's my wrong usage, but I do not know how to figure out.
>> Good luck
> still there is no wtwdis or unlocd
> I run
> ogrinfo -al --config S57_PROFILE iw 1W7ML310.000 POINT
> Warning 6: 'ON#' is an unexpected value for RETURN_PRIMITIVES open option of type boolean.
> Warning 6: 'ON#' is an unexpected value for RETURN_LINKAGES open option of type boolean.
> Warning 6: driver S57 does not support open option RETURN_TXTDSC
> Warning 6: driver S57 does not support open option RETURN_INFORM
> Warning 6: driver S57 does not support open option RETURN_NINFORM
> Warning 6: driver S57 does not support open option RETURN_NOBJNM
> Warning 6: driver S57 does not support open option RETURN_OBJNAM
> Warning 6: driver S57 does not support open option RETURN_NTXTDS
> INFO: Open of `1W7ML310.000'
>        using driver `S57' successful.
> Layer name: Point
> Geometry: Point
> Feature Count: 0
> Extent: (11.497309, 52.187832) - (11.647561, 52.275467)
> Layer SRS WKT:
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          SPHEROID["WGS 84",6378137,298.257223563,
>              AUTHORITY["EPSG","7030"]],
>          AUTHORITY["EPSG","6326"]],
>      PRIMEM["Greenwich",0,
>          AUTHORITY["EPSG","8901"]],
>      UNIT["degree",0.0174532925199433,
>          AUTHORITY["EPSG","9122"]],
>      AUTHORITY["EPSG","4326"]]
> RCID: Integer (10.0)
> PRIM: Integer (3.0)
> GRUP: Integer (3.0)
> OBJL: Integer (5.0)
> RVER: Integer (3.0)
> AGEN: Integer (5.0)
> FIDN: Integer (10.0)
> FIDS: Integer (5.0)
> LNAM: String (16.0)
> LNAM_REFS: StringList (16.0)
> FFPT_RIND: IntegerList (1.0)
> NAME_RCNM: IntegerList (3.0)
> NAME_RCID: IntegerList (10.0)
> ORNT: IntegerList (1.0)
> USAG: IntegerList (1.0)
> MASK: IntegerList (3.0)
> and
> ogr2ogr --config S57_PROFILE iw -skipfailures -f CSV x.csv 1W7ML310.000 -nlt POINT
> also does not extract the needed values.
> Best Wulf
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
