[gdal-dev] gdal-2.4.3 build dies at libiso8211.a
Even Rouault even.rouault at spatialys.com
Fri Dec 13 01:50:53 PST 2019
On jeudi 12 décembre 2019 22:37:32 CET Sean Darcy wrote:
> Building gdal-2.4.3 on Fedora 31, gcc-9.2.1. This happens even though
> configure has --disable-static, which is recognized:
> checking whether to build shared libraries... yes
> checking whether to build static libraries... no
> Any suggestions appreciated.
You are doing a manual "make 8211dump" from frmts/iso8211, right ? Well, as
this is mostly debug stuff not built by default, support for static builds
might be broken. You may need to tweek the makefile.
Works at least for me for a shared + non-libtool build.
http://www.spatialys.com
