[gdal-dev] gdal-2.4.3 build dies at libiso8211.a
Even Rouault even.rouault at spatialys.com
Sun Dec 15 09:02:26 PST 2019
> > How would I do a "non-libtool build" ?
--without-libtool
> Maybe a better questions is:
> why is gdal trying to build a static library when --disable-static is
> specified? Is there any way to _really_ disable static ?
GDAL build system uses autoconf, but not automake. The makefile are hand
written, so some of the autoconf options will have no real effect. If you want
to disable the static lib, the best is to delete manually libgdal.a after
libgdal.so has been generated.
Even
http://www.spatialys.com
