[gdal-dev] patch: s57objectclasses.csv for distance marks from IENC [add wtwdis; unlocd]
Even Rouault even.rouault at spatialys.com
Thu Dec 19 04:06:56 PST 2019
On jeudi 19 décembre 2019 12:46:05 CET wulf wrote:
> Hi developers,
> attached, there is a patch for
> s57objectclasses.csv against git commit 94431c2
> 191c191
> < 17004,Distance
> mark,dismar,catdis;wtwdis;unlocd;DATEND;DATSTA;NOBJNM;OBJNAM;,INFORM;NINFOM
> ;NTXTDS;PICREP;SCAMIN;TXTDSC;updmsg;,SORDAT;SORIND;,G,Point; ---
> > 17004,Distance
> > mark,dismar,catdis;DATEND;DATSTA;NOBJNM;OBJNAM;,INFORM;NINFOM;NTXTDS;PICR
> I'm not competent if this is a correct solution, but with that version
> I'm able to extract the needed values.
Can you submit this as a pull request by editing
https://github.com/OSGeo/gdal/blob/master/gdal/data/s57objectclasses.csv
(possibly directly from github UI ?)
So you've added
;wtwdis;unlocd
Is that right ?
Where does this come from ? I can't see that on http://www.s-57.com/ . Or are
they specific to the particular profile of S57 you use ?
http://www.spatialys.com
