[gdal-dev] PROJ6?
Darafei "Komяpa" Praliaskouski me at komzpa.net
Fri Feb 1 12:36:05 PST 2019
Thanks Even, Michael!
Changed order, left rebuilding and left for Moscow. Hope it finishes well
without oversight.
On пт, 1 лют 2019, 23:25 Even Rouault <even.rouault at spatialys.com> wrote:
> On vendredi 1 février 2019 23:20:58 CET Darafei "Komяpa" Praliaskouski
> wrote:
> > https://github.com/postgis/postgis-build-env
> Looking at
> https://github.com/postgis/postgis-build-env/blob/master/Dockerfile
> , it looks like you're building PROJ after GDAL. This should be the other
> way
> round. GDAL used to be able to load PROJ with dlopen() mechanism, but this
> is
> no longer the case, so proper compilation order is now needed.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190201/c393e4f2/attachment.html>
