[gdal-dev] Nearblack Eating Image Border
Daniel Morissette dmorissette at mapgears.com
Wed Feb 20 05:07:25 PST 2019
I noticed this behavior as well and I think it's a bug. I think it would
make more sense to keep the last "-nb" pixels that are not nearblack
instead of dropping them.  The effect is especially annoying when you
have image tiles and you end up with a 1-2 pixels gap between them.
I didn't test what happens if we change the behavior. So maybe there is
a reason why it was implemented this way?
Daniel
On 2019-02-19 6:13 p.m., Christopher Mitchell wrote:
> I've encountered an error in an image processing pipeline I've built
> where nearblack is removing pixels at the border of images, even if
> they don't fit the is-"black" criterion. Specifically, I'm using
> nearblack to remove nearly-black areas touching the edges of lossy
> image tiles that should be fully black. Those images are later
> combined into VRT files and warped; where we have multiple tiles
> overlapping an area, some of which are missing data, we therefore can
> get complete coverage.
> Unfortunately, for tiles that have no black areas, nearblack is still
> eating the -nb argument's number of pixels at the edges, turning them
> into black (0, 0, 0, 0, where we're using 4-channel images), even if
> those pixels are nowhere near the color criterion to be recognized as
> black. My understanding was that nearblack should only be proceeding
> into the interior of the non-black area and then setting pixels to
> black if those pixels are /actually/ nearly black.
> Am I encountering a bug with nearblack? Do I misunderstand how the -nb
> argument works? Happy to provide a MWE if any of the above is unclear,
> and thanks in advance.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
