[gdal-dev] shapelib 1.5.0 release
Even Rouault even.rouault at spatialys.com
Thu Feb 28 08:14:35 PST 2019
(CC'ing gdal-dev as well, since shapelib at lists.osgeo.org has likely lower
audience)
I've released shapelib 1.5.0
The main change is the removal of the 'shpproj' contrib utility and thus PROJ
dependency.
The tarballs are available at:
http://download.osgeo.org/shapelib/shapelib-1.5.0.tar.gz
http://download.osgeo.org/shapelib/shapelib-1.5.0.zip
The log of changes since 1.4.1 is:
2019-02-28  Even Rouault  <even.rouault at spatialys.com>
	* shpopen.c: resync with GDAL internal shapelib to avoid being dependent
	on correctness of file size field in .shp. Fixes
	https://lists.osgeo.org/pipermail/gdal-dev/2018-October/049218.html
	* contrib/shpgeo.h/.c: Remove PROJ.4 dependency and functionality,
	 causing removal of SHPProject(), SHPSetProjection() and
SHPFreeProjection()
	* contrib/shpproj.c: removed
2018-08-16  Even Rouault  <even.rouault at spatialys.com>
	* shpopen.c, dbfopen.c, shptree.c, sbnsearch.c: resyc with GDAL
	internal shapelib. Mostly to allow building those files as C++
	without warning. Also add FTDate entry in DBFFieldType
	(see https://github.com/OSGeo/gdal/pull/308). And some other
	code cleanups
	* dbfopen.c: fix a bug where the end of file character was
	written on top of the first character of the first field name
	when deleting a field on a .dbf without records.
	Fixes https://github.com/OSGeo/gdal/issues/863
2018-06-15  Even Rouault  <even.rouault at spatialys.com>
	* safileio.c: remove duplicate test. Patch by Jaroslav Fojtik.
	Fixes http://bugzilla.maptools.org/show_bug.cgi?id=2744
Even
http://www.spatialys.com
