[gdal-dev] How to correctly initialize GDAL library in a multithreaded environment?
Even Rouault even.rouault at spatialys.com
Mon Jan 14 03:16:25 PST 2019
> I have a multithreaded application that uses GDAL. Generally it works fine,
> but sometimes I have a hang when trying to create transformations from
> different threads.
> Seems like race condition occures when initializing static CPLMutex
> *hConfigMutex located in gdal\port\cpl_conv.cpp file;
On which operating system and with which GDAL version ?
With recent enough GDAL versions, and on Linux/Unix, I believe that mutex
creation should now be thread-safe. But there might still be issues on
Windows. We should be able to fix that more easily with C++11 mutex now.
Please file a ticket about that on
https://github.com/OSGeo/gdal/issues with the above requested details.
> I was able to fix the issue by calling a function that initializes the mutex
> before calls from different threads(just calling the following code:
> CPLGetConfigOption("GDAL_DATA", nullptr);) but it doesn't feel right.
Calling a function like GDALRegisterAll() that involves mutex creation before
creating any thread has been the historical recommandation
Even
http://www.spatialys.com
