[gdal-dev] Geoserver/gdal: large tif with multiple overviews - bug + workaround
Idan Miara idan at miara.com
Wed Jan 16 02:59:51 PST 2019
Even,
Thanks for your pointer!
It does solve the problem for me!
Andrea,
Thanks for you input!
Should I find the time to look into these issues I'll contact you.
I'm working on a python wrapper for gdal translate/wrap/info python
functions.
I'll open source it once it's done, hopefully it will help others with the
issues I encountered.
On Mon, 14 Jan 2019 at 12:59, Andrea Aime <andrea.aime at geo-solutions.it>
wrote:
> On Mon, Jan 14, 2019 at 11:52 AM Idan Miara <idan at miara.com> wrote:
>> Hi Andrea,
>> Thanks for very prompt reply and for your suggestions!
>> I'm wondering if it worth the effort to debug the current gdal-geoserver
>> plugin.
>> I remember we talked in FOSS4G about the gdal 2.x support in Geoserver,
>> is there any progress with that?
> Not at the moment, no one has been sponsoring that work.
>> I could also reproduce the following bug (
>> https://osgeo-org.atlassian.net/browse/GEOS-8143) for loading a vrt file
>> but not for the internal GeoTiff loader.
> Sorry to hear that. Anyone is free to provide a fix or sponsor one.
> As Paul Ramsey said (if memory serves me well) "in open source one gets
> what everybody else is paying for". Current sponsored activity does not
> seem to match your needs, sorry :-)
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf
> Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa
> (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549
> http://www.geo-solutions.it http://twitter.com/geosolutions_it
> ------------------------------------------------------- *Con riferimento
> alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 -
> Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni
> circostanza inerente alla presente email (il suo contenuto, gli eventuali
> allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i
> destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per
> errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le
> sarei comunque grato se potesse darmene notizia. This email is intended
> only for the person or entity to which it is addressed and may contain
> information that is privileged, confidential or otherwise protected from
> disclosure. We remind that - as provided by European Regulation 2016/679
> “GDPR” - copying, dissemination or use of this e-mail or the information
> herein by anyone other than the intended recipient is prohibited. If you
> have received this email by mistake, please notify us immediately by
> telephone or e-mail.*
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190116/0a60a2e9/attachment.html>
