[gdal-dev] Geoserver/gdal: large tif with multiple overviews - bug + workaround
Idan Miara idan at miara.com
Wed Jan 16 03:58:38 PST 2019
I'm using this python API, I didn't know theses tests which do help (as the
python API is not as documented as the c++ API).
I feel we're off topic here so I'll publish it soon in another thread in
the gdal-dev list.
Thanks!
On Wed, 16 Jan 2019 at 13:36, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 16 janvier 2019 12:59:51 CET Idan Miara wrote:
> > Even,
> > Thanks for your pointer!
> > It does solve the problem for me!
> > Andrea,
> > Thanks for you input!
> > Should I find the time to look into these issues I'll contact you.
> > I'm working on a python wrapper for gdal translate/wrap/info python
> > functions.
> Hum, are you aware that they are already such wrappers in recent GDAL
> versions with the GDAL Python bindings ? gdal.Info(), gdal.Translate(),
> gdal.Warp() ?
> Usage examples:
> https://github.com/OSGeo/gdal/blob/master/autotest/utilities/test_gdalinfo_lib.py
> https://github.com/OSGeo/gdal/blob/master/autotest/utilities/test_gdal_translate_lib.py
> https://github.com/OSGeo/gdal/blob/master/autotest/utilities/test_gdalwarp_lib.py
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190116/3f489d13/attachment.html>
