[gdal-dev] [Non-DoD Source] Re: ogr not reading the prj file
TUELLER, SHAYNE R CIV USAF AFMC 519 SMXS/MXDEC shayne.tueller at us.af.mil
Tue Jan 22 11:08:15 PST 2019
I think your first point is obvious...lol.
I was just trying to understand why GDAL_DATA wasn't required in my older version in order for SRS info to display in the ogrinfo app. You have answered that question. Thank you.
Shayne
-----Original Message-----
Sent: Tuesday, January 22, 2019 11:51 AM
To: gdal-dev at lists.osgeo.org
Cc: TUELLER, SHAYNE R CIV USAF AFMC 519 SMXS/MXDEC <shayne.tueller at us.af.mil>; jratike80 <jukka.rahkonen at maanmittauslaitos.fi>
Subject: Re: [gdal-dev] [Non-DoD Source] Re: ogr not reading the prj file
On mardi 22 janvier 2019 18:20:46 CET TUELLER, SHAYNE R CIV USAF AFMC 519 SMXS/MXDEC wrote:
> Thanks for the reply. However, this didn't address my question
> regarding why I don't need GDAL_DATA defined in gdal 1.11 in order for
> SRS info to print out...
If software didn't change between versions, there would be no point in releasing new versions :-)
So yes since GDAL 2.3, the shapefile driver now needs to access to the GDAL resource .csv files for nominal behaviour. (Actually if they are absent, you should still get the same, or similar, result as in 1.11)
Even
Spatialys - Geospatial professional services http://www.spatialys.com
