[gdal-dev] ubuntu_1804
Alan Stewart astewart at terragotech.com
Fri Jan 25 04:41:41 PST 2019
Thanks for the clarification.
On Jan 25, 2019, at 1:05 AM, Craig de Stigter <craig.destigter at koordinates.com<mailto:craig.destigter at koordinates.com>> wrote:
I didnt write it but I had to fiddle with the build scripts quite a bit for the  pytest refactor. Travis only supports Trusty (recently added Xenial, though I don't think GDAL is using that yet either.)
The ubuntu_1804 job builds an entire Ubuntu 18.04 install in a chroot (using debootstrap) inside the travis Trusty environment. It's not terribly elegant but gets the job done. So the kernel is the travis trusty kernel but the userland is ubuntu 18.04.
Hope that clarifies things.
Craig de Stigter
On Fri, 25 Jan 2019, 12:34 Alan Stewart, <astewart at terragotech.com<mailto:astewart at terragotech.com>> wrote:
The raw log for the ubuntu_1804 Travis job (specifically #15454.1) seems to indicate that the OS is Ubuntu 14.04 . From the build name I assumed it would be Ubuntu 18.04?
Alan Stewart
Senior Software Engineer
TerraGo Technologies
3200 Windy Hill Road, Suite 1550W
Atlanta, GA 30339 USA
O.  +1 678.391.9615
www.terragotech.com
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190125/f3c02ca3/attachment.html>
