[gdal-dev] ogr2ogr dxf multilinestring as block
andrew terry andrew.terry at centremaps.co.uk
Thu Jan 31 06:34:59 PST 2019
As per the documentation, i'm seeing mulitlinestring being split up into
LWPOLYLINE elements.
I'd like to make them a block and have tried adding a "blockname" column and
given each multilinestring a unique reference.
I've also tried the DXF_INLINE_BLOCKS set to FALSE option.
Is this possible and if so, is there an example anywhere?
Thanks
Andy
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
