[gdal-dev] Could not write Japanese characters in Shapefiles
Even Rouault even.rouault at spatialys.com
Sun Jul 7 02:29:27 PDT 2019
On dimanche 7 juillet 2019 08:34:03 CEST tor21sor at protonmail.com wrote:
> Hi,
> Great to find an awesome geospatial library!
> I could read the field names of a shapefile in Japanese characters by
> applying the following setting in Python 3 program.
> os.environ['SHAPE_ENCODING'] = "Shift_JIS"
For writing, this needs to be defined as the layer creation option ENCODING of
CreateLayer()
lyr = ds.CreateLayer(layer_name, geom_type, srs, options = ["ENCODING=SJIS"])
This will write a .cpg file with "SJIS" inside.
Or "ENCODING=LDID/19". The later will not write any .cpg file at all.
Even
http://www.spatialys.com
