[gdal-dev] vsicurl access to a netcdf file does not see the coordinates
Joaquim Manuel Freire Luís jluis at ualg.pt
Sat Jun 1 11:35:15 PDT 2019
Thanks Even
Rebuilding my HDF+netCDF+GDAL stack, but now when issue the final
nmake /f makefile.vc devinstall
it errors after a while with (complains about doxygen). This didn't use to happen. I have a Win doxygen but it's not (never been) in the path.
make: Entering directory '/c/programs/compa_libs/gdal_GIT/gdal/doc'
mkdir -p build/xml && cd .. && ((cat Doxyfile | sed "s/PREDEFINED             = /PREDEFINED             = DOXYGEN_XML /"; printf "GENERATE_HTML=NO\nGENERATE_XML=YES\nXML_OUTPUT=doc/build/xml\nXML_PROGRAMLISTING=NO") | doxygen -)
/bin/sh: doxygen: command not found
make: *** [Makefile:22: .doxygen_up_to_date] Error 127
make: Leaving directory '/c/programs/compa_libs/gdal_GIT/gdal/doc'
NMAKE : fatal error U1077: 'C:\MinGW64\msys64\usr\bin\make.EXE' : return code '0x2'
Stop.
|>-----Original Message-----
|>From: Even Rouault <even.rouault at spatialys.com>
|>Sent: Saturday, June 1, 2019 9:38 AM
|>To: gdal-dev at lists.osgeo.org
|>Cc: Joaquim Manuel Freire Luís <jluis at ualg.pt>
|>Subject: Re: [gdal-dev] vsicurl access to a netcdf file does not see the
|>coordinates
|>On vendredi 31 mai 2019 23:49:09 CEST Joaquim Manuel Freire Luís wrote:
|>> Hi,
|>> GDAL master here
|>> When I run gdalinfo on a remote nc file, instead of reporting the
|>> coordinates it prints the array size
|>Joaquim,
|>Note that in the /vsicurl/ case, the file gets opened by the HDF5Image driver
|>whereas in the non vsicurl case, by the netCDF driver, hence the difference.
|>A recent enough version (4.5 I believe) of libnetcdf must be used so that /
|>vsicurl/ can be used by the netCDF driver (you must see 'NetCDF has
|>netcdf_mem.h: yes' in configure output)
|>Even
|>Spatialys - Geospatial professional services http://www.spatialys.com
