[gdal-dev] Issues installing gdal from source code
Jorge Martin jormarfe at gmail.com
Thu Jun 6 02:27:57 PDT 2019
Hello,
First of all, thanks for you answer!
I have checked what you say, I list more steps and additional information:
1)      check “cpl_string.h" and only one file is found:
      >> gdal-2.2.1]# find / -name cpl_string.h
       /root/gdal-2.2.1/port/cpl_string.h
2)      Compiler version:
      >> g++ --version
        g++ (GCC) 4.1.2 20070626 (Red Hat 4.1.2-14)
                 SO: Red Hat 5.1
3)      I have tried with gdal 2.2.1, 2.2.2, 2.2.3 and the result is the
same.
4)      I have tried with “make –j11” and 3 errors are returned:
                >> cd /root/gdal-2.2.1
               >> ./configure --with-libtiff=/opt/cots/tiff-4.0.0
--with-geotiff=/opt/cots/geotiff-1.4.0 --prefix=/opt/cots/gdal
               >> make –j11
ERRORS:
libtool: compile:  gcc -I/opt/cots/gdal/port -I/opt/cots/gdal/gcore
-I/opt/cots/gdal/alg -I/opt/cots/gdal/ogr -I/opt/cots/gdal/ogr/o
grsf_frmts -I/opt/cots/gdal/gnm -I/opt/cots/gdal/apps
-DHAVE_SSSE3_AT_COMPILE_TIME -DHAVE_SSE_AT_COMPILE_TIME -g -O2 -Wall
-Wdeclara        tion-after-statement -Wextra -Winit-self
-Wunused-parameter -Wmissing-prototypes -Wmissing-declarations -Wformat
-Wshadow -DGNM_ENAB        LED -I/opt/cots/gdal/port
-I/usr/include/netcdf-3 -I/opt/cots/geotiff-1.4.0/include
-I/opt/cots/tiff-4.0.0/include -DGDAL_COMPILATIO        N -c gxf_proj4.c
-fPIC -DPIC -o ../o/.libs/gxf_proj4.o
cpl_string.cpp: In function 'int CPLVASPrintf(char**, const char*,
__va_list_tag*)':
cpl_string.cpp:1042: error: declaration of 'int CPLVASPrintf(char**, const
char*, __va_list_tag*)' throws different exceptions
cpl_string.h:284: error: from previous declaration 'int
CPLVASPrintf(char**, const char*, __va_list_tag*) throw ()'
cpl_string.cpp: In function 'int CPLvsnprintf(char*, size_t, const char*,
__va_list_tag*)':
cpl_string.cpp:1134: error: declaration of 'int CPLvsnprintf(char*, size_t,
const char*, __va_list_tag*)' throws different exception        s
cpl_string.h:244: error: from previous declaration 'int CPLvsnprintf(char*,
size_t, const char*, __va_list_tag*) throw ()'
cpl_string.cpp: In function 'int CPLsnprintf(char*, size_t, const char*,
cpl_string.cpp:1330: error: declaration of 'int CPLsnprintf(char*, size_t,
const char*, ...)' throws different exceptions
cpl_string.h:253: error: from previous declaration 'int CPLsnprintf(char*,
size_t, const char*, ...) throw ()'
make[1]: *** [cpl_string.lo] Error 1
make[1]: Leaving directory `/opt/cots/gdal/port'
make: *** [port-target] Error 2
make: *** Waiting for unfinished jobs....
/bin/sh /opt/cots/gdal/libtool --mode=compile --tag=CXX g++
-I/opt/cots/gdal/port -I/opt/cots/gdal/gcore -I/opt/cots/gdal/alg
-I/opt/cots/gdal/ogr -I/opt/cots/gdal/ogr/ogrsf_frmts -I/opt/cots/gdal/gnm
-I/opt/cots/gdal/apps -DHAVE_SSSE3_AT_COMPILE_TIME
-DHAVE_SSE_AT_COMPILE_TIME -g -O2  -Wall -Wextra -Winit-self
-Wunused-parameter -Wformat -Wshadow -Wnon-virtual-dtor
-Woverloaded-virtual -fno-operator-names  -I.. -I../..   -I/usr/include
-I/usr/include -DGNM_ENABLED -I/opt/cots/gdal/port -I/usr/include/netcdf-3
-I/opt/cots/geotiff-1.4.0/include -I/opt/cots/tiff-4.0.0/include
-DGDAL_COMPILATION -DHAVE_EXPAT -DHAVE_SQLITE -c -o ../o/gmlhandler.lo
gmlhandler.cpp
libtool: compile:  g++ -I/opt/cots/gdal/port -I/opt/cots/gdal/gcore
-I/opt/cots/gdal/alg -I/opt/cots/gdal/ogr -I/opt/cots/gdal/ogr/ogrsf_frmts
-I/opt/cots/gdal/gnm -I/opt/cots/gdal/apps -DHAVE_SSSE3_AT_COMPILE_TIME
-DGDAL_COMPILATION -DHAVE_EXPAT -DHAVE_SQLITE -c gmlhandler.cpp  -fPIC
-DPIC -o ../o/.libs/gmlhandler.o
gmlhandler.cpp:1887: error: expected `}' at end of input
make[3]: *** [../o/gmlhandler.lo] Error 1
make[3]: Leaving directory `/opt/cots/gdal/ogr/ogrsf_frmts/gml'
make[2]: *** [gml-target] Error 2
make[2]: *** Waiting for unfinished jobs....
-Woverloaded-virtual -fno-operator-names  -DGNM_ENABLED
-DGDAL_COMPILATION -c -o ../o/ehdrdataset.lo ehdrdataset.cpp
-Woverloaded-virtual -fno-operator-names -DSQLITE_ENABLED
-I/usr/include/libxml2 -DHAVE_LIBXML2 -I../frmts/gtiff -I../frmts/mem
-I../frmts/vrt -I../ogr -I../ogr/ogrsf_frmts/generic -I../gnm/
-I../gnm/gnm_frmts/ -I/opt/cots/gdal/ogr/ogrsf_frmts/geojson/libjson
-I../ogr/ogrsf_frmts/geojson -DGNM_ENABLED -I/opt/cots/gdal/port
-I/opt/cots/tiff-4.0.0/include -DGDAL_COMPILATION -DPAM_ENABLED -c
gdalpamproxydb.cpp  -fPIC -DPIC -o .libs/gdalpamproxydb.o
make[3]: Leaving directory `/opt/cots/gdal/ogr/ogrsf_frmts/gmt'
make[2]: Leaving directory `/opt/cots/gdal/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory `/opt/cots/gdal/ogr'
make: *** [ogr-target] Error 2
Do you have any other idea to fix this issue? I do not know why this error
is appearing, becasuse in the past I compile and install gdal 1.8.X in the
same machine without any issue.
Can you help me? Thanks in advance!
El mié., 5 jun. 2019 a las 13:50, Andrew Bell (<andrew.bell.ia at gmail.com>)
escribió:
> Perhaps I'm missing something, but I'm seeing no throw specifications on
> my 2.1 source.  I'm guessing you're finding header files from a version
> that is different from the version you're trying to compile.  I'd search
> your system for "cpl_string.h" and compare with the include directories
> used during compilation.
> On Wed, Jun 5, 2019 at 6:30 AM Jorge Martin <jormarfe at gmail.com> wrote:
>> Hello,
>> Trying to compile gdal 2.1.1 we are getting the following error:
>> --with-geotiff=/opt/cots/geotiff-1.4.0 --prefix=/opt/cots/gdal_v2
>> make
>> (cd port; make)
>> make[1]: Entering directory `/data2/mvit/gdal-2.1.1/port'
>> __va_list_tag*)':
>> cpl_string.cpp:1034: error: declaration of 'int CPLVASPrintf(char**,
>> const char*, __va_list_tag*)' throws different exceptions
>> cpl_string.h:215: error: from previous declaration 'int
>> __va_list_tag*)':
>> cpl_string.cpp:1124: error: declaration of 'int CPLvsnprintf(char*,
>> size_t, const char*, __va_list_tag*)' throws different exceptions
>> cpl_string.h:195: error: from previous declaration 'int
>> CPLvsnprintf(char*, size_t, const char*, __va_list_tag*) throw ()'
>> cpl_string.cpp:1305: error: declaration of 'int CPLsnprintf(char*,
>> size_t, const char*, ...)' throws different exceptions
>> cpl_string.h:197: error: from previous declaration 'int
>> CPLsnprintf(char*, size_t, const char*, ...) throw ()'
>> our system is Red Hat Enterprise Linux Server release 5.1 (Tikanga) and
>> we have installed previous version of gdal in the machine.
>> We also have tried to install other versions such as 2.2.1, 2.2.2 and
>> 2.2.3 and we got the same error. The vesion that we have installed is
>> 1.8.1.
>> Regards,
>> Jorge
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190606/6ba95b91/attachment-0001.html>
