[gdal-dev] Is there an easy way to clip an image to the realdata?
lars.schylberg at blixtmail.se lars.schylberg at blixtmail.se
Thu Jun 27 07:30:57 PDT 2019
Hi Steve,
Sorry for the late reply!
I have some scripts that I developed this winter that contains a function
to clip an image or images to the parts that only contains data.
My aim was to create tighter tile indexes for Mapserver.
I achieved good results for my use case.
This will be one of the topics that I will present in my talk at
FOSS4G in Bucharest in August.  I haven't yet prepared the details how to
explain what I did.  But here we go:
1) First I retile the data to suitable size,
2) then check for empty tiles that I throw away.
The function "trim_tile" is actually what You are asking for, I think.
What I do in the function trim_tile is to use:
1) gdal_calc to produce a binary image where I have data
2) polygonize where data exists
3) compare extents
4) clip data with gdal_translate with projwin argument, if polygon extent is smaller
All is done in a bash script, since it is my preferred language to do things fast.
I use gnu parallel to speed things up. In my case I had 16 cpus in the server.
Some versions of parallel requires the argument "--will-cite", others don't.
I made my own bash version of retiling that keeps masks.
Further notes is that the script is working on paletted tif 8 bit image.
I have a version for rbg images also.  The main difference is that the
empty image test looks like this in that case:
STDDEV=$(gdalinfo $tile -stats | \
	grep STATISTICS_STDDEV | \
	sed 's/STATISTICS_STDDEV=//g' | \
	awk '{$1=$1;printf "%d", $1}')
	if [ "$STDDEV" = "000" ]; then
		/bin/rm $tile
	fi
If You have tagged nodata values, those have to be removed with gdal_edit.py
before You run statistics and then reaplied afterwards with gdal_edit again.
This might hopefully give some inspiration for you how to tackle your
use case.
The full script can be found here:
https://gist.github.com/LarsSchy/9ecb31eb964dd83820c139b2f2769a7c
Have fun
Lars Schylberg
20 juni 2019 kl. 22:06, "Stephen Woodbridge" <stephenwoodbridge37 at gmail.com> skrev:
> Hi,
> I'm working with VIIRS L3U images of L2P (level 2 patches). The L3U data
> is gridded to the +-180 x +-90 but the patch only fills a small
> percentage of that. I'm compositing a the patch for a day using a vrt.
> Performance is an issue because all the patches cover the whole globe
> instead of the extents of the patch.
> Is there a way to automatically clip an image to the extents of the
> patch, where all the rest of the image it filled with nodata? IE. remove
> all rows and columns from the exterior edges that are all nodata and
> stop when you hit real data.
> -Steve
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
