[gdal-dev] gdal.BuildVRT with an empty destination
Patrick Young patrick.mckendree.young at gmail.com
Tue Mar 12 15:42:34 PDT 2019
Hi all,
I was browsing some GDAL test cases and came across some tests like so:
ds = gdal.BuildVRT('',...)
aka the destination is an empty string.  Is the returned dataset a purely
in memory object in this case?  I assume it is safe to use like any other
dataset; some of the other VRT related tests are using "/vsimem/..." as the
destination, wasn't sure if one form should be prefered over another for
quick in memory vrt building.
Thanks,
Patrick
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190312/a83175c9/attachment.html>
