[gdal-dev] Encoding of keys and values returned by GDALGetMetadata?
Sean Gillies sean at mapbox.com
Tue Mar 26 16:35:45 PDT 2019
Even,
On Tue, Mar 26, 2019 at 2:57 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> > Little is said at
> > https://www.gdal.org/gdal_8h.html#a25929a66e99d92c2788485ecf13e2e82. Are
> > these values UTF-8 (as was the intent in
> > https://trac.osgeo.org/gdal/wiki/rfc5_unicode) or does it depend on the
> > format driver?
> The key/value mechanism itself just assumes NUL-terminated strings. The
> general aim of GDAL should be to have UTF-8 everywhere, but the reality is
> that not all drivers enforce this, so you might easily end up with
> 'random'
> encodings.
I'll watch out for this.
> > In https://github.com/mapbox/rasterio/issues/1663 a rasterio
> > user is encountering HDF5 metadata items that can't be decoded using
> > Python's UTF-8 codec and I've love to be able to sort this out.
> OK, looking at the details of this particular case, this is an
> inappropriate
> handling by the HDF5 driver of some types of attributes.
> Fixed by
> https://github.com/OSGeo/gdal/commit/9640098fc79b6ba6bb135f8715fa3e7dd2705691
> which I've backported to 2.4 as well
> Even
Thanks for the quick fix!
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190326/0d784e53/attachment.html>
