[gdal-dev] Compression not applying when updating/exiting GeoTiff file in GDAL?
taylorday.assimila at gmail.com taylorday.assimila at gmail.com
Fri Mar 29 02:02:08 PDT 2019
Hi all,
I posted this question on GIS SE (link
<https://gis.stackexchange.com/questions/317009/compression-not-applying-whe
n-updating-exiting-geotiff-file-in-gdal?noredirect=1#comment515654_317009> )
but have not had any luck, so was wondering if anyone here could help.
I have a `GeoTiff` file with dimensions 300 x 300 and 8760 bands (hourly for
one full year). I am testing some code that opens the file, updates ONE band
and exits - but I am finding that the file size almost doubles when I exit
the file, despite the new band being the same data type etc. Code is as
follows:
I am creating the `GeoTiff` file using the following creation options using
many singular `GeoTiff` files:
    gdal_merge.py -separate -co BIGTIFF=YES -co COMPRESS=DEFLATE -co
PREDICTOR=1 -co TILED=YES -co BLOCKXSIZE=64 -co BLOCKYSIZE=64 -o block64.tif
*.tif
The file size is 947MB.
I am then updating the file using the following code:
    ds = gdal.Open("block64.tif", gdal.GA_Update)
    # Some simple operation to change band values
    arr = ds.GetRasterBand(11).ReadAsArray() / 2
    ds.GetRasterBand(11).WriteArray(arr)
    ds.FlushCache()
    ds = None
The file size is now 1.9GB.
My preliminary conclusion is that the compression/creation options are not
being applied once I've updated and exited the file. Is there any way to
re-compress/reapply the options once I close the file?
Current options:
1.	read file, make changes, save to a new file - this is not ideal as
saving the file each time I want to make an update is slow and this
operation is happening server-side and needs to be as quick as possible.
2.	Use VRTs - This is a good option, but I'd like all bands in one
GeoTiff to make I/O as quick as possible when extracting time series data,
so a VRT wrapper does not help with updating the base file.
Any help would be greatly appreciated.
Many thanks,
Taylor
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190329/c1d6d0b0/attachment.html>
