[gdal-dev] Should the next version (previously 2.5) be called GDAL 3.0 ?
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed May 1 13:36:56 PDT 2019
I like 3.0 as well.  -jeff
On 2019-05-01 3:56 PM, Even Rouault wrote:
> Hi,
> As a feedback from the previous motion, it appears that GDAL 3.0 would
> probably better reflect the API & behaviour changes that have been done,
> and
> be in accordance with our HOWTO-RELEASE procedure and semantic versionning
> rules.
> I'm OK with that change.
> If we decide for that, the plan would probably be:
> - change in docs & other materials the references to 2.5 to 3.0
> - create a release/3.0 branch from the HEAD of release/2.5
> - abandon release/2.5 branch (that is: backports would be done in
> release/3.0,
> and for longer support in release/2.4 when appropriate)
> - issue a 3.0.0RC1 from that
> - call master 3.1dev
> Thoughts ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
