[gdal-dev] EPSG code with vertical datum
Andrew Bell andrew.bell.ia at gmail.com
Wed May 29 17:38:02 PDT 2019
In earlier GDAL versions I could call
SetFromUserInput("EPSG:4326+4326");
without error.  I now get the following error:
(Error) GDAL failure (1) SetCompoundCS() fails, vertical component is not
VERT_CS.
Was this a failure to detect a problem in older GDAL versions or is this a
regression in version 3.0?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190529/900c9199/attachment.html>
