[gdal-dev] Python Bindings and Closed Datasets
Even Rouault even.rouault at spatialys.com
Fri Nov 1 06:42:09 PDT 2019
Patrick,
with your updated script, the good & bad news is that I can reproduce it quite
reliably, including with GDAL master on a debug build. I strongly suspect a
subtle race issue in the global GDAL block cache or in the way the GTiff
driver interacts with it, rather than something Python specific.
Even
http://www.spatialys.com
