[gdal-dev] GDAL 3, PROJ 6.2 exportToProj4() drops Datum silently
Even Rouault even.rouault at spatialys.com
Thu Nov 7 03:30:44 PST 2019
On jeudi 7 novembre 2019 11:10:26 CET Roger Bivand wrote:
> On Thu, 7 Nov 2019, Even Rouault wrote:
> > On jeudi 7 novembre 2019 15:24:44 CET Nyall Dawson wrote:
> >> On Wed, 30 Oct 2019 at 06:16, Even Rouault <even.rouault at spatialys.com>
> > wrote:
> >>>> I realise this too, but to permit legacy results to be replicated,
> >>> Some legacy behaviour was just plain wrong/inaccurate. Trying to
> >>> replicate
> >>> it in PROJ would be heartbreaking, an extra maintaince burden, and a
> >>> confusion for PROJ users because depending on the path they take, they
> >>> would get different results.
> >>> Not-so-random example with GDAL 2.4/PROJ 5 with GDA94 to GDA2020
> >>> You get a ~1.5 metre shift to the north east as expected.
> >> This thread has been bouncing around in my mind for the last week.
> >> Forgive me if I'm misinterpreting the situation, but wouldn't you
> >> explicitly want legacy results NOT to be reproducible in cases where
> >> proj 6's more accurate transformation capabilities have affected these
> >> results?
> >> If a particular study isn't affected by relatively small shifts such
> >> as the 1.5m shift in the GDA2020 situation, then the results should
> >> remain reproducible even if this shift is corrected. But if a
> >> particular study IS affected by distances of this magnitude then I'd
> >> argue that it would be vital that the older proj behavior can't be
> >> reproduced exactly, and accordingly the previous study/results are
> >> invalidated as a direct result..!
> > Are you saying that the new behaviour of ExportToProj4() shouldn't cause
> > issues ? Well, that's more subtle than that. As +towgs84 terms might be
> > omitted more often now, you can get differences of ~ 100 metres when
> > dealing with datums dating before the GPS era. So when using GDAL 3
> > ExportToProj4() you can effectively get "wrong" results in some cases.
> > The action I took for now is to document the issue with ExportToProj4():
> > https://gdal.org/doxygen/
> > classOGRSpatialReference.html#a271b3de4caf844135b0c61e634860f2b
> The red-lined Warning is very explicit:
> "Use of this function is discouraged. Its behaviour in GDAL >= 3 / PROJ >=
> 6 is significantly different from earlier versions. In particular +datum
> will only encode WGS84, NAD27 and NAD83, and +towgs84/+nadgrids terms will
> be missing most of the time. PROJ strings to encode CRS should be
> considered as a a legacy solution. Using a AUTHORITY:CODE or WKT
> representation is the recommended way."
> I think importFromProj4() is more forgiving - is this likely to continue,
> or should we move away from Proj4 anyway?
importFromProj4() is likely to continue to exist in the foreseable future.
There are various raster/vector formats that use PROJ.4 strings to encode the
CRS, so we want to still be able to decode them.
What is discouraged is the generation of new PROJ.4 CRS strings from now.
Even
http://www.spatialys.com
