[gdal-dev] GDAL/OGR curve stroking dfMaxAngleStepSizeDegrees
agisar scott at agi.com
Tue Nov 12 04:49:44 PST 2019
It looks like the answer is "4 degrees unless the user has overridden the
value with the OGR_ARC_STEPSIZE configuration variable", as found in
gdal-3.0.2/ogr/ogrgeometryfactory.cpp:3884.
Hope that helps.
Scott
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
