[gdal-dev] Discrepancy when tiling on MAC and Linux
Grégory Bataille gregory.bataille at gmail.com
Wed Nov 13 20:54:09 PST 2019
wow, thanks.
I'm not quite sure I'm following it all though. I'm reaching a bit my
knowledge limit here with those transforms. I'll need to spend a bit more
time on it to get more understanding and see what I can do, how I might use
your update.
But thanks for the quick turnaround
Cheers
Gregory Bataille
On Thu, Nov 14, 2019 at 1:24 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> > This is not a PROJ6 issue, but a GDAL one related to the logic starting
> at
> > https://github.com/OSGeo/gdal/blob/master/gdal/ogr/ogrct.cpp#L843
> > You could try to add a test that if OGRSpatialReference::GetTOWGS84()
> > returns OGRERR_NONE then the resolution to the WKT of the EPSG code is
> > skipped
> I've implemented this in https://github.com/OSGeo/gdal/pull/2016
> The last commit is the one that is of interest for you. I've kept the
> current
> behaviour as default, as I think it is what most people would want. For
> your
> use case, you'd define OSR_CT_USE_DEFAULT_EPSG_TOWGS84=YES
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191114/dcd8dc79/attachment.html>
