[gdal-dev] gdalwarp overhead on linux but not on windows
alex at vautier.biz alex at vautier.biz
Tue Nov 19 08:35:42 PST 2019
Hi guys,
I've been playing quite a lot with "wrapper_GDALWarpDestName" and a .net
core wrapper (https://github.com/MaxRev-Dev/gdal.netcore/).
Everything is running fine, I'm quite happy to see the same behavior on
windows and linux. Sometimes linux is faster for reading and writing
raster, this is great ! .NET Core is (now) a very good option for cross
platform dev. Anyway...
When calling wrapper_GDALWarpDestName,  I'm experiencing an overhead of
350 to 500 ms on linux that I don't see at all on Windows.
To narrow down the issue, I tried many warp options (-multi; -wo
NUM_THREADS=4; -wm 2000), output drivers (MEM, VRT, NWT_GRD), input file
format (MEM, VRT, NWT_GRD), input and output projections. I also checked
Gdal.GetCacheUsed(), Gdal.HasThreadSupport() and Gdal.GetCacheMax(),
same values between linux and windows. Nothing helps.
Even with VRT format output, this overhead is present which proves this
is not related to processing. I bet for some sort of initialization of
the warp algorithm with file reading... because 400 ms is far from
nothing. But I'm wondering why this is occurring for every single call
on linux and not on windows... Any option I could try ? My next step is
to profile the linux process but I'm not good at that so any help there
would be great too.
     OS (version): Windows 10 (1903)
     Docker:
     Server: Docker Engine - Community
     Engine:
     Version: 19.03.2
     API version: 1.40 (minimum version 1.12)
     Go version: go1.12.8
     Git commit: 6a30dfc
     Built: Thu Aug 29 05:32:21 2019
     OS/Arch: linux/amd64
     Experimental: false
     Linux in docker file: debian 9
(mcr.microsoft.com/dotnet/core/runtime:2.2-stretch-slim)
     Package version (core): [e.g. 3.0.1.25]
     Package version (runtime windows): [e.g. 3.0.1.25]
     Package version (runtime linux): [e.g. 3.0.1.2]
This is the kind of code I'm running:
namespace GdalCoreTest
  class Program
   static void Main(string[] args)
	GdalBase.ConfigureAll();
	Console.WriteLine("GDAL configured");
	Console.WriteLine(string.Join('\n',
		"GDAL Version: " + Gdal.VersionInfo("RELEASE_NAME"),
		"GDAL INFO: " + Gdal.VersionInfo("")));
	WarpFile();
	WarpFile();
	WarpFile();
   public static void WarpFile()
	Stopwatch sw = new Stopwatch();
	int sizeX = 1024, sizeY = 1024;
	var driver = Gdal.GetDriverByName("MEM");
	string path = $"/vsimem/test.mem";
	string vrtFilePath = null;
	using(Dataset ds = driver.Create(path, sizeX, sizeY, 1,
DataType.GDT_UInt32, new string[0]))
	  try
	  //create a grid
		ds.SetGeoTransform(new double[]{0, 30, 0, 0, 0, -30});
		var ttt = new SpatialReference(null);
		ttt.ImportFromProj4("+proj=longlat +datum=WGS84");
		ttt.ExportToWkt(out string latLongWkt, new string[0]);
		ds.SetProjection(latLongWkt);
		//write data in the buffer
		int[] buffer = new int[sizeX * sizeY];
		for (int x = 0; x < sizeX; x++)
		  for (int y = 0; y < sizeY; y++)
			buffer[y * sizeX + x] = x + y;
		ds.GetRasterBand(1).WriteRaster(0, 0, sizeX, sizeY, buffer, sizeX,
sizeY, 0, 0);
		//Prepare for warping
		IntPtr[] ptr = {Dataset.getCPtr(ds).Handle};
		GCHandle gcHandle = GCHandle.Alloc(ptr, GCHandleType.Pinned);
		var dss = new
SWIGTYPE_p_p_GDALDatasetShadow(gcHandle.AddrOfPinnedObject(), false,
null);
		vrtFilePath = $"/vsimem/tile.vrt";
	  //Warp
		sw.Start();
		using (Dataset dst = Gdal.wrapper_GDALWarpDestName(vrtFilePath, 1,
dss, new GDALWarpAppOptions(new[]{"-of", "VRT" }), null,null))
		  sw.Stop();
	  finally
		Gdal.Unlink(path);
		Gdal.Unlink(vrtFilePath);
     Console.Out.WriteLine($"Warp duration = {sw.ElapsedTicks} ticks
({sw.ElapsedMilliseconds} ms).");
This is the output I'm getting on windows:
GDAL configured
GDAL Version: 3.0.1
GDAL INFO: GDAL 3.0.1, released 2019/06/28
Warp duration = 221267 ticks (22 ms).
Warp duration = 133395 ticks (13 ms).
Warp duration = 155402 ticks (15 ms).
This is the output I'm getting on docker/linux:
GDAL configured
GDAL Version: 3.0.1
Warp duration = 395911725 ticks (395 ms).
Warp duration = 368923383 ticks (368 ms).
Warp duration = 373055090 ticks (373 ms).
Thanks,
Alex.
