[gdal-dev] vrt guidance: 31 band classified raster
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Thu Oct 3 16:43:55 PDT 2019
Matt,
Have you tried create a cascading VRT, where the first VRT composites
all the GTiff files into a single virtual raster and then reference the
composite in another VRT that assigns colortable. I think this should
work nicely.
-Steve W
On 10/3/2019 7:01 PM, Matt.Wilkie at gov.yk.ca wrote:
> Hello gdal-dev, it's been a long time!  I'm happy to be digging into
> raster data building again for a change, but could use some nudges in
> the right direction(s).
> A few weeks ago Nasa released Landsat-derived Annual Dominant Land
> Cover Across ABoVE Core Domain, 1984-2014
> <https://daac.ornl.gov/ABOVE/guides/Annual_Landcover_ABoVE.html>.
> It’s composed of 175 geotiff images, with each file containing 31
> bands which in turn correspond to a single year in the 1984-2014
> period. Each band is 8bit unsigned integer with values from 1 to 15
> and 255 as nodata. Each integer value corresponds to a class such as
> “Evergreen Forest”, “Herbaceous”, “Water” and so on.
> I’ve been successful in manually building a VRT file using Category
> element for the classes and ColorTable entry for a palette – but only
> for a single band.
> My question is: how to properly apply this to all bands? Do I need
> duplicate category and colortable elements to every single
> VRTRasterBand element or is there a smart way to define it once and
> then refer to it like a variable?  Am I even approaching this the
> right way?
> It was quite a bit of work to get this far and I’m not looking forward
> to doing this 30 more times.
> Sample vrt and simplified source is attached.
> *Matt Wilkie*
> Geomatics Analyst
> Environment | Information Management & Technology
> T 867-667-8133 | Yukon.ca <http://yukon.ca/>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
