[gdal-dev] Is it generally possible to write multipart result into zip with ogr2ogr?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 3 23:52:51 PDT 2019
The shapefile documentation declares "Starting with GDAL 3.1, the driver can also support reading, creating and editing .shz files (ZIP files containing the .shp, .shx, .dbf and other side-car files of a single layer) and .shp.zip files (ZIP files contains one or several layers)" but is it possible somehow to write any multipart response (like MapInfo MIF/tab) directly into zip file with ogr2ogr?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191004/bb273790/attachment.html>
