[gdal-dev] Specifying output format gives wrong result
Schmitz, Uwe uwe.schmitz at bezreg-koeln.nrw.de
Fri Oct 4 04:19:39 PDT 2019
Folks,
no idea or interest in this issue?
Or are there problems with the download?
I can send them via pm if desired.
Best wishes
Uwe
>-----Ursprüngliche Nachricht-----
>Von: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] Im Auftrag von
>Schmitz, Uwe
>Gesendet: Montag, 2. September 2019 12:25
>An: gdal-dev at lists.osgeo.org
>Betreff: [gdal-dev] Specifying output format gives wrong result
>Folks,
>I try to filter a dem (456664_40m.tif) with the help of
>a .vrt (456664gf.vrt) to get 456664gf.tif. The result is incorrect.
>It looks like it's slightly pushed together vertically in the middle of
>the dataset. Please look at 456664gf.tif, compare it to the
>original 456664_40m.tif and you see what I mean.
>The command is simple:
>> gdal-config --version
>2.4.0
>> gdal_translate -ot Float32 -of GTiff 456664gf.vrt 456664gf.tif
>Now the surprising: if I omit the "-of Float32" argument,
>the result looks ok. It may be of interest that former versions
>(2.1.x/2.2.x don't remember exactly) didn't have this
>problem.
>I uploaded the aforementioned files (zip archive) here:
>http://www.keepandshare.com/doc12/view.php?id=249308&da=y
>Thanks in advance
>Uwe
>_______________________________________________
>gdal-dev mailing list
>https://lists.osgeo.org/mailman/listinfo/gdal-dev
