[gdal-dev] Motion: approve GDAL 2.4.3RC1 and 3.0.2RC1 as final
Sean Gillies sean at mapbox.com
Thu Oct 31 06:46:56 PDT 2019
Even, I've built 3.0.2rc1 and didn't find any new issues. +1
On Thu, Oct 31, 2019 at 5:09 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> A few issues [1] have been fixed since in those branches since the RCs,
> but
> they predated 2.4.0, so those new releases are not worse than their
> previous
> x.y.0, so I move to
> +1 Even
> [1]
> - PDS: fix opening of datasets with BSQ organization (or single band),
> where
> one band is larger than 2 GB (2.3 regression)
> - IRIS: make identification more restrictive to avoid false-positive
> identification of raw binary formats such as ENVI (fixes #1961)
> - OGRLinearRing::isPointOnRingBoundary(): fix incomplete test that could
> falsely return true if the point was aligned with a segment, but not
> between
> the nodes. Impact correct reconstruction of holes in shapefile driver
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20191031/89e584c9/attachment.html>
