[gdal-dev] Question on gdal_contour and limiting the range of contours generated.
Stephen Woodbridge stephenwoodbridge37 at gmail.com
Thu Oct 31 07:59:43 PDT 2019
Jukka,
Thanks! After trying shapefile and exceeding 2GB, I switched to postgres
and deleted the elevation as you suggested.
I'm working with a global relief model the includes both elevation and
bathymetry depth over the whole world at about 15 arc-sec/pixel. I
generates a lot of contour lines between 8,000 and -10,000 meters, I was
think it would be handy to gdal_dem had a few more options to control
the range and direction of contour generation.
I also have played with gdal_calc to create an elevation and bathymetry
only files.
Thanks, I think I have workarounds for the moment.
-Steve W
On 10/31/2019 4:38 AM, jratike80 wrote:
> Second thought, perhaps I would just delete unnecessary contour lines
> afterwards instead of flattening the DEM.
> gdal_contour -f gpkg -a elev -off -121.92 -i 1.524
> bathy-value/crm_vol2.nc.tif bathy-contours/crm_vol2.nc-5.gpkg
> ogrinfo -sql "delete from crm_vol2.nc-5 where elev>0"
> ogrinfo -sql "VACUUM" bathy-contours/crm_vol2.nc-5.gpkg
> -Jukka-
> jratike80 wrote
>> Hi,
>> I believe I would use gdal_calc https://gdal.org/programs/gdal_calc.html
>> and
>> make the terrain above the sea level flat before creating the contours.
>> And
>> I would avoid shapefiles and use GeoPackage as output format.
>> There is a button "Edit on GitHub" in the top-right corner on page
>> https://gdal.org/programs/gdal_contour.html, feel free to test it.
>> -Jukka Rahkonen-
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
