[gdal-dev] ogr2ogr.py sqlite dialect unsupported?
Even Rouault even.rouault at spatialys.com
Mon Sep 2 09:19:46 PDT 2019
ogr2ogr.py is a toy / sample file which receives little maintainance, and was
mostly a one-time port of the ogr2ogr.cpp source, which is the on used by the
command line utility.
You may use the 'librarified' ogr2ogr with the gdal.VectorTranslate() Python
function. Examples at
https://github.com/OSGeo/gdal/blob/master/autotest/utilities/
test_ogr2ogr_lib.py#L63
Even
http://www.spatialys.com
