[gdal-dev] ogr2ogr
Reynolds, Scott scott at agi.com
Wed Sep 4 11:33:13 PDT 2019
A quick look at the GDAL source in gdal-3.0.1\ogr\ogrsf_frmts\aeronavfaa\ograeronavfaadatasource.cpp suggests that the code is not processing the file format correctly and therefore not identifying the file as a Daily DOF.  I would try to fix it, but I can't get PROJ to build on Windows using Visual Studio because CMake can't find SQLite binary.
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of paul.malm at lfv.se
Sent: Wednesday, September 4, 2019 08:46
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] ogr2ogr
I don't know if this is the correct forum.
I would like to fonvert a aeronavFAA obstacle file to the Esri shape format.
>From all the information I can find on internet I think this should be correct:
C:\Program Files\GDAL>ogr2ogr -f "ESRI Shapefile" c:\temp\FAAdof13_ga  C:\Downloads\FAA_DOF\13-GA.DAT
This is the error message I get:
FAILURE:
Unable to open datasource `C:\Users\anpaumal\Downloads\shapefiler\FAA_DOF\13-GA.DAT' with the following drivers.
  -> `netCDF'
  -> `PCIDSK'
  -> `PDS4'
  -> `JP2OpenJPEG'
  -> `PDF'
  -> `MBTiles'
  -> `EEDA'
  -> `DB2ODBC'
  -> `ESRI Shapefile'
  -> `MapInfo File'
  -> `UK .NTF'
  -> `OGR_SDTS'
  -> `S57'
  -> `DGN'
  -> `OGR_VRT'
  -> `REC'
  -> `Memory'
  -> `BNA'
  -> `CSV'
  -> `NAS'
  -> `GML'
  -> `GPX'
  -> `LIBKML'
  -> `KML'
  -> `GeoJSON'
  -> `GeoJSONSeq'
  -> `ESRIJSON'
  -> `TopoJSON'
  -> `Interlis 1'
  -> `Interlis 2'
  -> `OGR_GMT'
  -> `GPKG'
  -> `SQLite'
  -> `ODBC'
  -> `WAsP'
  -> `PGeo'
  -> `MSSQLSpatial'
  -> `PostgreSQL'
  -> `MySQL'
  -> `OpenFileGDB'
  -> `XPlane'
  -> `DXF'
  -> `CAD'
  -> `Geoconcept'
  -> `GeoRSS'
  -> `GPSTrackMaker'
  -> `VFK'
  -> `PGDUMP'
  -> `OSM'
  -> `GPSBabel'
  -> `SUA'
  -> `OpenAir'
  -> `OGR_PDS'
  -> `WFS'
  -> `WFS3'
  -> `HTF'
  -> `AeronavFAA'
  -> `Geomedia'
  -> `EDIGEO'
  -> `GFT'
  -> `SVG'
  -> `CouchDB'
  -> `Cloudant'
  -> `Idrisi'
  -> `ARCGEN'
  -> `SEGUKOOA'
  -> `SEGY'
  -> `ODS'
  -> `XLSX'
  -> `ElasticSearch'
  -> `Walk'
  -> `Carto'
  -> `SXF'
  -> `Selafin'
  -> `JML'
  -> `PLSCENES'
  -> `CSW'
  -> `VDV'
  -> `GMLAS'
 -> `MVT'
  -> `TIGER'
  -> `AVCBin'
  -> `AVCE00'
  -> `NGW'
  -> `HTTP'
I can see that the driver AeronavFAA is tested, since it is listed above, what am I doing wrong?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20190904/915cb910/attachment.html>
