[gdal-dev] GPKG to PostgreSQL, version 2.2.3 vs version 3.0.2
Ari Jolma ari.jolma at gmail.com
Thu Apr 9 07:23:23 PDT 2020
Same outcome.
There's something very strage going on as the max of the id is 305926
(after creating the table with the first gpkg) but when I try to
manually insert a row to the table it says "key id=39 already exists".
If I then manually setval the sequence to 305926 I can add to the table.
So somehow the sequence is lagging behind.
Ari
jratike80 kirjoitti 9.4.2020 klo 16.14:
> Hi,
> I would have a try with -unsetfid. That should be the default when in append
> mode but the test is easy.
> -Jukka Rahkonen-
> Ari Jolma-2 wrote
>> I have this command
>> ogr2ogr -update -append -f PostgreSQL PG:... merged.gpkg
>> which works ok in version 3.0.2 (self-compiled) but not in 2.2.3 (from
>> ubuntu apt). The error is
>> ERROR: duplicate key value violates unique constraint "stand_pkey"
>> DETAIL: Key (id)=(1) already exists.
>> CONTEXT: COPY stand, line 1
>> STATEMENT: COPY "stand" ("wkb_geometry", "standid", "parcelid",
>> "realestateid", "standnumber", "standnumberextension", "maingroup",
>> "subgroup", "fertilityclass", "soiltype", "drainagestate",
>> "ditchingyear", "thinningyear", "developmentclass", "standquality",
>> "maintreespecies", "accessibility", "standinfo", "datasource",
>> "growthplacedatasource", "area", "areadecrease", "creationtime",
>> "updatetime") FROM STDIN;
>> The issue is that "stand_pkey" is "CONSTRAINT stand_pkey PRIMARY KEY
>> (id)" made by the
>> ogr2ogr -overwrite -f PostgreSQL PG:... merged.gpkg
>> earlier. So it shouldn't be in the COPY data at all (the log does not
>> show whether it is there) or there is something wrong with the sequence.
>> Is there a way to make it work in the older version?
>> Ari
>> gdal-dev mailing list
>> gdal-dev at .osgeo
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev at lists.osgeo.org
