[gdal-dev] GPKG to PostgreSQL, version 2.2.3 vs version 3.0.2
Ari Jolma ari.jolma at gmail.com
Fri Apr 10 00:07:20 PDT 2020
Ari Jolma kirjoitti 10.4.2020 klo 9.54:
> This seems to be the case. v 3.0.2 sends
> SELECT setval(pg_get_serial_sequence('"stand"', 'id'), MAX("id") FROM
> "stand";
> and similar for other tables but v 2.2.3 does not.
The fix was committed 9 Sep 2017 as a fix to #7032 to versions 2.3 and
up but not to 2.2, which is what one still gets by default in ubuntu 18.04.
Probably a quick fix would be to issue those sequence update commands
after all data load commands.
Ari
