[gdal-dev] Building for Java on MacOS
Andrew C Aitchison andrew at aitchison.me.uk
Mon Apr 27 10:52:01 PDT 2020
On Mon, 27 Apr 2020, David Rush wrote:
> Ivan:
> Thanks!  That worked.  On to the next error (with make in gdal/swig/java)
> gdalconst_wrap.c:154:10: fatal error: 'jni.h' file not found
> #include <jni.h>
> 1 error generated.
> make: *** [gdalconst_wrap.lo] Error 1
> Where *should* jni.h come from?  I can't find it anywhere in my Java
> installation.
I believe it should be in the JDK (Java Development Kit)
- do you just have the JRE or Java Runtime Environment ?
Andrew C. Aitchison					Kendal, UK
