[gdal-dev] Reading a JP2 file - obj_decode() failed
Even Rouault even.rouault at spatialys.com
Mon Aug 10 06:24:07 PDT 2020
On dimanche 9 août 2020 20:34:28 CEST Jonathan Moules wrote:
> I guess this is what you want:
>          <Field name="XTsiz" type="uint32">132000</Field>
>          <Field name="YTsiz" type="uint32">248000</Field>
> Which I'm assuming means it's not tile.
Indeed. Do you know which libopenjp2 version is used ?
Do you read a subset of the file ? Does the file appear immediately or after a
few successful windowed reads ?
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200810/0ae30a7c/attachment.html>
