[gdal-dev] gdal_translate -scale
jesus.moran at solute.es jesus.moran at solute.es
Mon Dec 14 03:04:08 PST 2020
Hello GDAL team and thank you for welcome me.
I have an issue with the gdal_translate command. I would like to use the
“STATISTICS_MIN” and “STATISTICS_MAX” metadata key values in the -scale
parameter of the program, so I don’t need to specify it manually every time
I want to scale the output. Is there any way to do this?
Thanks a lot in advance!
 <http://www.solute.es/>
Jesús Maria Morán Rosado
Project Engineer
Av. Cerro del Águila, 3, 28703 S.S. de los Reyes, Madrid
CONFIDENTIALITY: This e-mail and any attachments are confidential and may be
privileged. If you are not a named recipient, please notify the sender
immediately and do not disclose the contents to another person, use it for
any purpose or store or copy the information in any medium.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201214/6ff76be8/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201214/6ff76be8/attachment.gif>
