[gdal-dev] Geotransform for non-North-up images?
G Seiffert hh1 at posteo.de
Mon Dec 21 09:23:17 PST 2020
Thanks Javier, but as it looks the way I did works great. Got rid of the
XY shift as well. Rotation affects the calculations for the origin as
well, of course, this is what I needed to correct. In case of 0 vs 90
deg rotation the fix was simple. Will now work on trig formulas that
work with any rotation angle.
G
> Javier Jimenez Shaw <mailto:j1 at jimenezshaw.com>
> 21 December 2020 14:02
> I am not sure, but I guess that you have to negate also GT5: y axis is
> reversed between image coordinates and "geographic" coordinates.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> G Seiffert <mailto:hh1 at posteo.de>
> 21 December 2020 12:57
> Thanks Javier. Need to confess: math is not my strong side. I'm more
> the "trial and error" guy. And - shame on me - Google.
> Got the rotation AND the scaling correct meanwhile, calculating the
> params as described here:
> https://gis.stackexchange.com/questions/69715/rotating-rasters-using-gdal-geotransform-and-arcgis-desktop?noredirect=1&lq=1
> Below a code snippet (I work in Python). However,  with the exact
> calcs from above website, my pics were rotated correctly but for some
> strange reason mirrored vertically! Try and error: Making GT(4)
> negative got rid of the mirroring. So almost happy now, just facing a
> weird shift of 2m to west and 0.7m to south, working on it.
> # ROTATION PART Start ================================================
>     rot_deg = 90
>     rotation = np.deg2rad(rot_deg)
>     GT0 = orig_x
>     GT1 = math.cos(rotation) * image_resolution
>     GT2 = -math.sin(rotation) * image_resolution
>     GT3 = orig_y
>     GT4 = -math.sin(rotation) * image_resolution
>     GT5 = math.cos(rotation) * image_resolution
>     geotrans = (GT0, GT1, GT2, GT3, GT4, GT5)
> # ROTATION PART End ================================================
> Thanks so far! Also Thomas and Jukka!
> Gerhard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> 21 December 2020 10:55
> Those transformation parameters can be seen as a 3x3 transformation
> matrix like this
> Xg     GT1 GT2 GT0     Xp
> Yg  =  GT4 GT5 GT3  *  Yp
>  1      0   0   1       1
> Where [Xp, Yp] is the coordinate in pixels, and [Xg, Yg] is the
> "geographic" coordinate (whatever it means ;)
> the 2x2 top left corner of the transformation matrix can be seen as a
> 2D rotation-scaling matrix:
> https://en.wikipedia.org/wiki/Transformation_matrix#Examples_in_2_dimensions
> [GT0, GT3]is the "geographic" coordinate of the pixel [0,
> 0](regardless rotation or scaling)
> Cheers
> 21 December 2020 10:24
> Hi all from GDLA.
> Thanks for the opportunity to as a question. It's regarding the
> Geotransform
> Tutorial(https://gdal.org/tutorials/geotransforms_tut.html). Tried to
> get info in the web but since this seems a tricky one, my searches failed.
> The tutorial only deals with the ideal case of 'North up' images, for
> which GT(2) and GT(4) are zero. However, my images are 'East up' and
> potentially 'any direction up' (underwater photomosaic surveys by
> ROV). The rotation works with '90' for GT(2, 4). But the scaling seems
> completely ignored. Any hint? If it would be easy, I assume your
> tutorial would give an example for how to deal with "non-N-up' images,
> but ...
> My pics are 1920x1080, with pixel resolution of 0.0015 (yes, 0.15cm
> per pixel, we're flying just 3m above the bottom).
> In case I rotate the images prior to geotransform (in Photoshop),
> geotransform works perfect, with GT(2, 4) = 0. Scaling spot on. I can
> live with that for our last survey but I'm also looking for a solution
> in case our survey heading cannot be 0, 90, 180, or 270, but has to be
> something like 35° (due to bottom currents etc.).
> Best regards, any hint qappreciated,
> Gerhard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201221/c1534e0e/attachment.html>
