[gdal-dev] Can't build GDAL 3.0.X to read GML format on Linux (Ubuntu 18.04)
Michaël Landry michael.landry at hotmail.com
Wed Feb 5 04:33:31 PST 2020
I found the problem.
Even though I was running a new configure file and calling make clean each time to remove the last built files, some files like config.status were not updated so the installation was running with the same faulty configuration over and over. It seems I could add configuration options, but I could not remove what had already been added.
Before calling ./configure, I had to call make distclean to remove everything that was installed by configure. The command make clean removes things that were generated by Make and the command make distclean removed things that were generated by Configure and Libtools.
I still don't know why my old configuration was not working... but now it works so I don't need to investigate.
Have a nice day!
De : Michaël Landry
Envoyé : 2 février 2020 09:12
À : gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Objet : Can't build GDAL 3.0.X to read GML format on Linux (Ubuntu 18.04)
I have successfully built and tested GDAL 3.0.1 and 3.0.4 with the SWIG java bindings and everything works fine except that I can't read GML format files. When I call the java method ogr.open( .. ), it always returns null. I investigated and i found out that I cannot open GML files with the ogrinfo app either. It seems the problem is on the native side and not on the bindings side. Here is the output of the command ogrinfo --formats for the app.
[cid:2fd2948e-3523-4798-a6b1-c35c2e941e0b]
I am using a configure script to build my makefiles. I read online at https://gdal.org/drivers/vector/gml.html​ that XERCES or EXPAT is needed to read gml files. I first started to build with only EXPAT and now I am building with EXPAT and XERCES, but I still can't read GML files. Here is my configuration output from the console.
C++14 support:             no
  LIBTOOL support:           yes
  LIBZ support:              external
  LIBLZMA support:           no
  ZSTD support:              no
  cryptopp support:          no
  crypto/openssl support:    no
  GRASS support:             no
  CFITSIO support:           no
  PCRaster support:          internal
  LIBPNG support:            internal
  DDS support:               no
  GTA support:               no
  LIBTIFF support:           internal (BigTIFF=yes)
  LIBGEOTIFF support:        internal
  LIBJPEG support:           internal
  12 bit JPEG:               yes
  12 bit JPEG-in-TIFF:       yes
  LIBGIF support:            internal
  JPEG-Lossless/CharLS:      no
  OGDI support:              no
  HDF4 support:              no
  HDF5 support:              no
  Kea support:               no
  NetCDF support:            no
  Kakadu support:            no
  JasPer support:            no
  OpenJPEG support:          no
  ECW support:               yes
  MrSID support:             yes
  MrSID/MG4 Lidar support:   no
  JP2Lura support:           no
  MSG support:               no
  EPSILON support:           no
  WebP support:              no
  cURL support (wms/wcs/...):yes
  PostgreSQL support:        no
  LERC support:              yes
  MySQL support:             no
  Ingres support:            no
  Xerces-C support:          yes
  Expat support:             yes
  libxml2 support:           no
  Google libkml support:     no
  ODBC support:              no
  FGDB support:              no
  MDB support:               no
  PCIDSK support:            internal
  OCI support:               no
  GEORASTER support:         no
  SDE support:               no
  Rasdaman support:          no
  DODS support:              no
  SQLite support:            yes
  PCRE support:              no
  SpatiaLite support:        no
  RasterLite2 support:       no
  Teigha (DWG and DGNv8):    no
  INFORMIX DataBlade support:no
  GEOS support:              no
  SFCGAL support:            no
  QHull support:             internal
  Poppler support:           no
  Podofo support:            no
  PDFium support:            no
  OpenCL support:            no
  Armadillo support:         no
  FreeXL support:            no
  SOSI support:              no
  MongoDB support:           no
  MongoCXX v3 support:       no
  HDFS support:              no
  TileDB support:            no
  userfaultfd support:       yes
I did not disable the gml driver and the makefile says that gml is built by default. Here is the list of the available formats listed for ogr where you can see gml.
[cid:4d09603f-8ab8-4bfb-9380-3e23227760f5]
Here is the call i make to configure and to make in my script file to build GDAL.
[cid:9db827de-93bd-401f-ae0a-1a881134d61a]
I also built GDAL 3.0.1 on Windows and the command ogrinfo --formats lists all the possible formats, including gml and maybe 50+ others. Is there a way to build gdal on linux so that all the formats are also available for ogr? I joined my script file to build gdal.
​Thank you for your time!
Michael
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200205/a440a4be/attachment-0001.html>
