[gdal-dev] Question about GDAL API: way to find out if CS is SPCS
Even Rouault even.rouault at spatialys.com
Fri Feb 7 09:30:00 PST 2020
> thanks for the answer. I am using C/C++ and I was expecting to find a
> function/method like "GetSPCSZone", "IzSPCS" or similar.
There's no such function. But you can just open the data/stateplane.csv file
to find a match of EPSG code.
An alternative is to use exportToWkt() with WKT2 output and look at the value
of CONVERSION[]
http://www.spatialys.com
