[gdal-dev] How far can we resolve complex GeoJSON?
Sean Gillies sean at mapbox.com
Fri Feb 14 08:39:29 PST 2020
Hi Jukka, Even,
On Thu, Feb 13, 2020 at 4:43 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> On jeudi 13 février 2020 21:06:57 CET Rahkonen Jukka (MML) wrote:
> > Hi,
> > Have a look at data returned by request
> https://beta-paikkatieto.maanmittauslaitos.fi/geographic-names/wfs3/v1/coll
> > ections/placenames/items?municipality=837&limit=100 There exists couple
> of
> > features with "parallelName" and GDAL converts that part into a string
> type
> > attribute
> -oo FLATTEN_NESTED_ATTRIBUTES=YES can improve things for a property that
> is a
> JSon object/dictionary, but not here because parallelName content is an
> array.
> >   parallelName (String) = [ { "placeNameId": 40581553,
> "placeNameVersionId":
> > 2, "spelling": "Pirkkahalli", "language": "fin", "languageOfficiality":
> 1,
> > "languageDominance": 1, "placeNameSource": 1, "placeNameStatus": 5,
> > "placeNameCreationTime": "2008-12-05T22:00:00Z",
> > "placeNameModificationTime": "2017-02-15T10:41:10Z",
> > "placeNameDeletionTime": null } ]
> > Can we do anything else with GDAL and GeoJSON driver? I suppose it does
> not
> > same kind of advanced features like GMLAS driver has.
> Indeed. The GeoJSON driver cannot create auxiliary layers for nested
> objects.
> Thinking that a fun exercise would be to write a script that would convert
> the
> GeoJSON content into XML (there are already utilities to do that) and
> generate
> a XML schema. And then feed that into GMLAS. Sounds fun, doesn't it ;-) ?
> Even
If this JSON is coming from a WFS, won't there be a JSON schema of some
kind provided by the server? Would using OGR's WFS3 driver instead of
GeoJSON help?
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200214/879a58b0/attachment.html>
