[gdal-dev] Docker images
Stéphane Brunner stephane.brunner at camptocamp.com
Mon Feb 17 01:11:48 PST 2020
Hello,
Le ven. 14 févr. 2020 à 21:50, Even Rouault <even.rouault at spatialys.com> a
écrit :
> Stéphane,
> > - How is the security is managed in those Docker images?
> Basically those images are built by a nightly cron job on my machine, and
> I
> don't think I've docker pull'ed the base Ubuntu image in recent times, so
> they
> are probably outdated. Currently you'd better apt update && apt upgrade if
> you
> care about the security patches from the OS provider (not sure what Alpine
> does on that respect)
You speak about the nightly build, the 'version' build (like
ubuntu-small-3.0.4
<https://hub.docker.com/layers/osgeo/gdal/ubuntu-small-3.0.4/images/sha256-f395f6f83adc5d3279e8d0bfe443213e7a8178757e93e0bbac2153c370b09a92?context=explore>)
is generated when the release is created and never after, right?
> > - How will new versions of distributions be managed?
> The usual answer: when someone is keen on updating them, pull requests
> gladly
> accepted, etc etc :-) For the Ubuntu based ones, I guess we should stick
> on
> LTR releases. For Alpine based ones, we can probably be more agressive in
> updates and switch to the latest version when it is available.
> Even
Thanks for your responses Even
CU Stéphane
> Spatialys - Geospatial professional services
> http://www.spatialys.com
*Stéphane Brunner*
Geospatial Solutions
Software Developer
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
camptocamp.com
mapfish.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200217/7893fdf6/attachment.html>
