[gdal-dev] XLS file can't be opened with gdal 3
Even Rouault even.rouault at spatialys.com
Fri Jan 10 05:57:44 PST 2020
On vendredi 10 janvier 2020 10:21:52 CET Frédéric Trastour wrote:
> Hi Tobias,
> Yes, gdal is linked against FreeXL 1.0.5 – and reports support for XLS.
> Note that some other XLS files can be used without problem.
> This one, which is included in out test suite doesn’t.
Same FreeXL version in your 2 GDAL builds ?
Looking quickly at the diff on the GDAL side in the ogr/ogrsf_frmts/xls, the
changes seem to be purely cosmetic.
Even
http://www.spatialys.com
