[gdal-dev] invalid data in spatial file
Even Rouault even.rouault at spatialys.com
Thu Jan 16 08:35:16 PST 2020
On jeudi 16 janvier 2020 11:59:30 CET Wuyyuru Ravi Teja Krishna wrote:
> Hello,
> The geojson file before conversion and csv file after conversion are
> attached below.
> the ogr2ogr command line used is
> java -cp :gdal.jar -Djava.library.path=libs/ ogr2ogr "-f" "CSV" "-t_srs"
> "CRS:84" gdaltampered.csv gdaltampered.geojson "-lco" "GEOMETRY=AS_WKT"
I don't reproduce the problem with recent versions of GDAL (2.4 and above)
Your original file is:
"type": "FeatureCollection",
"name": "ne_110m_geography_regions_points",
"features": [
{ "type": "Feature", "properties": { "scalerank": 2, "featurecla":
"waterfall", "name": "Niagara Falls"}, "geometry": { "type": "Point",
"coordinates": [ -643212.061818000385017, 5765.686896063275327 ] } },
"waterfall", "name": "Iguazu Falls"}, "geometry": { "type": "Point",
"coordinates": [ -52344.582997199603767, -25433.568291925005923 ] } }
The output:
WKT,scalerank,featurecla,name
"POINT (-643212.061818 5765.68689606328)","2",waterfall,Niagara Falls
"POINT (-52344.5829971996 -25433.568291925)","2",waterfall,Iguazu Falls
Note: it is quite risky to have a GeoJSON file using obviously non-WGS84
coordinates without specifying in it the CRS in which they are encoding. This
can confuse a lot of tools using GeoJSON.
Even
http://www.spatialys.com
